Head Studs Upgrade
SIBLY
Albuquerque
Cummins 6.7
I’m curious if upgrading the Head Studs is a suggestion or a necessity on a Cummings Turbo Diesel. Seems there’s a few videos on YT suggesting the upgrade.
Thoughts?
1500ram12
5.9L Cummins
If you plan on adding hp or towing a lot it's probably a good idea. Not a necessity. Although people have blown head gaskets just daily driving. But it could of just been a bad gasket or not totally telling the truth. For piece of mind if you have the means to do it, it can't hurt.
2018 2500 6.4L Hemi Tradesman
RedneckHippy
Washington
2019 Ram 3500 Tradesman
6.4 Hemi w/ MDS
If I were going to run higher PSI through the turbo than stock then I would consider it, but if it is stock just leave it be. That being said, it is a simple job if you want to blow the money on those head studs.
