Headlight bulb replacement options
badlldoit
maryland
I am not sure about Sirius. But it effects am/fm until about 35 mph then the truck must outrun the interference. It's the strangest thing. I am going to try some ferrite chokes as soon as I get a chance. Novsight says to try the resistors they sell, but they won't fit behind the dust cover. If the ferrites don't work I will be sending the bulbs back to Amazon. Then I will try a different brand that surely won't be such a good deal.
Darth
Chicago
I purchased the LED bulb upgrade from Vanquish Auto. I think I paid $120. Lights were very bright and great.....for nine months......then burned out. Now I'm back to the stock halogens :(
duckman631
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
Can’t say then that I might have same issue. I only use Sirius and I have a shorty antenna so fm sucked anyway with it so there is no way for me to test until I put them in my 2014 since that still has the stock antenna. I’ll try fm after I install them and see if I get same issue.
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
Updates on the Novsights on my end:
Lo-Beam H11s went in just fine, aligned perfectly.
Hi-beam 9005s were a raging pain in the butt, they almost align perfectly (not 9-3, but more like 9:30-3:30... but they're hi-beams so who cares?) and they barely fit into the housing (you have to be a little bit pushy with it, and be careful where you put the wiring - the fans still work fine, though; holding my ear up to the dust cover, I could hear them spinning w/o issues).
Oh, and no interference with Sirius XM at all (but I can hear a slight interference with AM radio - no FM stations reach out this far for me to test against.)
Bo Daggart
5.7L
Save yourself a head ache and don't mess with your headlights.
Random_Walk
Out
2017 QC 4WD SLT
Pentastar 3.6
Meh - I still have my old ones carefully packed. Out where I live, they really don't produce near enough light for the job (we, well, we don't do streetlights out in the country.)
south7west
Yee Haw Y'all
2014 Ram 1500 LoneStar
So I've got the stock halogen headlights and the only thing that has been holding me back from upgrading to LED is that I am afraid that the center dash screen will flash the message saying my bulbs are out. Is there a way to upgrade to LED's and trick the computer? I did a full conversion of LED's on my 06 F150 and it worked great for that truck, but then again it didn't have all those fancy electronics either!
pacofortacos
You can upgrade the stock halogens without going to LED.
I am quite happy with the H9's and 9011's. Cheap and no issues.
Random_Walk
Out
2017 QC 4WD SLT
Pentastar 3.6
Mine didn't require it (they plugged right in and lit up with no errors, no sweat), but an OBDLink MX fob, plus the AlfaOBD app on your phone, and you can modify pretty much anything on the computers...
Random_Walk
Out
2017 QC 4WD SLT
Pentastar 3.6
One last bit... This is the first vehicle ever that takes this much effort just to change a headlight...
Here's what it took last Tuesday:
duckman631
duckman631
New Jersey
Yup. Crazy design. YouTube videos show the guy removing lights without taking out grill and using a long extension to get bottom light housing bolt. Good luck with that because even with the grill off, that bolt was a pain and took forever to remove on both.
duckman631
duckman631
New Jersey
Ordered some 9006 yellow led fog bulbs. Can’t wait to see how they look because stock fogs look stupid with the led lows.
Random_Walk
Out
2017 QC 4WD SLT
Pentastar 3.6
I have a lowly SLT, thus no fog lights... :)
Random_Walk
Out
2017 QC 4WD SLT
Pentastar 3.6
Final update (since this morning was the first chance I got to actually do this comparison...)
Halogen pix taken on Sept. 10th , LED pix taken this morning, looking down my 500' driveway, front tires on the edge of the asphalt pad in front of the house (though it appears there's a shift to the right).
Lo-Beam: Halogen (L), LED (R)
Hi-Beam: Halogen (L), LED (R)
pacofortacos
Is it just the camera or does you LED's wash out the color that much?
KC Cryptkeeper
KCMO
2015 Ram1500
Easy if you use a magnetic socket and one 12" extension
Random_Walk
Out
2017 QC 4WD SLT
Pentastar 3.6
Both. The camera is a crappy LG G3 phone camera, but the higher blue tint of the LEDs will wash out the red colors a bit.
rockyj69
