Harold mcintosh
I have a 2002 ram 1500 with 5.9 passenger headlight don’t work on low beams and drivers side on high beams I’ve replaced the bulbs switch and checked wiring still no fix
I will check the relay, it may be the problem. Good luckI have a 2002 ram 1500 with 5.9 passenger headlight don’t work on low beams and drivers side on high beams I’ve replaced the bulbs switch and checked wiring still no fix
