Headlight Recommendations?
PersyDonkers
US
Probably not the right section to place this but idk if I'm just lucky and my 2012's headlight output is just garbage or if it was normal for that year. Looking for a decent plug and play upgrade. GF's Toyota low beams are brighter than my highs. Any recommendations?
BOWERSFJ
Uniontown OH
I did the Cougar Motor 3.0 LED’s from Amazon, in my Hi’s Lo’s and fogs ... Plug N Play ... Bright as hell ... Just wish I knew how to make the fogs stay on with the Hi’s ... FYI, I am 2012 as well
NJMOPAR
Older and faster
ELizabeth, NJ
Second the Cougar Motor ones. Also ran all 3 on my 2010 but recently switched to 6000k HID lows.
Still running the Cougar highs & fogs.
kurek
Northwest
Are you talking about sitting in the drivers seat, seeing far into the distance while driving at night? Or standing outside of your truck looking back at it and putting pictures on instagram? Those are two different and mostly unrelated definitions of brightness and they have two different approaches to addressing it.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Fogs dropout only work if you can modify the BCM via AlfaOBD.
P
PersyDonkers
US
Hahah. Definitely meaning as in the driver seat.
P
PersyDonkers
US
Will do on the Exterior side, kinda figured that would be the spot. But yea thanks for the recommendations.
GIJoe2010
Killeen, TX
Firetruck41
Washington State
2500 Mega Cab Hemi 5.7
Do you have a link to the specific ones that worked in the high beam? I have stock quad beam headlights and I just had to return these Cougar LEDs that did not fit high beams due to the fact that they stuck out beyond the dust cap.
Those Cougar LEDs do fit in my horizontal fogs though, and I am happy with them.
NJMOPAR
Older and faster
ELizabeth, NJ
Yep, the 9005s linked above are the exact ones I'm running in my 2010.
Fit under the caps no problem.
