- Mar 23, 2014
- 1,920
- 1,495
- Location
- Killeen, TX
- 2014
- Hemi 5.7
Mine's a 14 1500 and I too had to cut for the door and filter.
From what I have read the door is not fully seated ! It can be a pain,. If I remember right try hooking one side first then snap in the free side!. Did you cut the opening ? If so did you notch the lower cut out area ?Does anyone have any issue with the door not fitting snug and whistling at high speed? I'm using the k&n filter.
Sent from my SM-N950U using Tapatalk
xxxxxxDoes anyone have any issue with the door not fitting snug and whistling at high speed? I'm using the k&n filter.
I have a 2015, SO pulling the blower motor is fairly easy ? ThanksI did mine with a utility knife, PITA. But I took my time and did it right, seems to work rather well too. The dust that used to show on the dash is nowhere like it used to be, no whistling. I think I used a Chrysler 200 cabin filter for the application. I also pulled the blower motor and cleaned it out after install. It’s worth it! I am not sure when to change the filter. I’ve gone about 15,000 miles so far.
3 screws.I have a 2015, SO pulling the blower motor is fairly easy ? Thanks
Thanks I may pull mine this spring just to check !3 screws.
Extremely easy. I think 2 or 3 fasteners and it comes down! You can see them if you look under the dash after you remove the glove box.I have a 2015, SO pulling the blower motor is fairly easy ? Thanks
Thanks for the info. When our temps get above 11* Ill have to look lol. Which would be spring and It should be time to change the CAF so that will be a good time to look and yard it out ! That does sound like something I could do Thanks for the infoExtremely easy. I think 2 or 3 fasteners and it comes down! You can see them if you look under the dash after you remove the glove box.
Hows about Brought a filter kit for my 2016 Laramie from Genos garage and went to install it.. Took down glove box and **** the cover was already on the truck so I said not bad I,ll just change the filter now,and have a spare cover for the air box. When I finally got it opened Their was no filter on my truck from the factory they robbed me of a cabin filter on a 56,000 truck. Ram if your reading this Mail me a new Mopar cabin filter
old news but for you guys, per FRAM
CF11671
Length 8.53
Width 7.762
Height 0.985
CF10729
Length 8.51
Width 7.644
Height 1.005
