Heads up, tuning is available for our trucks
whetrick1
Musky Mike
NC
You do know that if you take your truck in and if they do an update that they will lock that computer and you won't be able to do and adjustments unless you Diablo to unlock it again.
Wonder if it’s possible to just buy the unlocked PCM with the tuner, take out the stock PCM and set it aside (would cost more without the PCM tradein). Then if you ever need to go to the dealer for anything you swap out the unlocked PCM for the stock one. Hmmm, will that work?
Look like you can purchase the PCM outright.
http://www.moes-performance.com/mobile/Product.aspx?ProductCode=I3-2019
Firebird
2019 Ram 2500
Yes, you can do that
bigdodge
Yes, it will work. That's what I did with my 15. Swapped pcm when going to the dealer. No problems at all but it is a lot more expensive.
Sent from my Pixel 3 XL using Tapatalk
Elkman
Monterey
V6
If only one could increase mpg and gain range with one of these tuners. More horsepower and faster shifting only means shorter life for the transmission and torque converter.
TatertotScott
The man, the myth, the legend, the one and only!
La Center/Amboy, WA
Faster shifting and less slip generally = longer transmission life.
Slipping is used only for comfort.
whetrick1
That’s what I did because if you need to take it back for warranty work I’ll put the original one back in.
Musky Mike
NC
I’ve been told the PCM and the odometer stores the mileage and if the dealer digs into the PCM they can see the difference. Don’t know if this is 100% true and if any dealer would look that deep for engine or transmission warranty work.
whetrick1
I’m not sure about that. That’s the chance I’ll have to take. But if you take it in and they flash the PCM then lock it you’ll have to have it unlocked again.
Fernando Bastidas
I've had this on my truck for about 2 weeks. I was having issues with Pulsar, and swapped it out for the i3. Been great so far, much better than the Pulsar.
Fernando Bastidas
How’s it compare to the Pulsar performance mode?
With the Diablo Tune 93 Oct, it feels about the same as the performance mode in the Pulsar. I cant say whether one has more power than the other, they both feel pretty equal under WOT.
The main difference I notice is drivability. The Diablosport feels like it's a factory tune. Throttle response is good but not too touch. The pulsar was way too sensitive in performance mode. You were constantly reminded that your had a piggyback tuner, with the diablosport it feels natural.
I was also having some issue with the pulsar, same as many people have had. No issues at all with the diablosport tuner
2014RamExpress
I really want to do this for my 2019 Ram, but I want to hear more reviews about custom tunes. I haven't seen many and I want to make sure it's worth the money.
whetrick1
Get ahold of Jay or Matt and get a custom tune and you'll really see the difference in a tuner and the pulsar
