Heavier coil spring lift?
2001ram15004x4
Yeah I figured whatever the guy did wasn't good so now I just have to try and fix it lol
2001ram15004x4
So what's the best 5 inch lift or 5.5 as I think they sell to that I can get without spending a lot of money
Johnn123
Ontario
Zone offroad or skyjacker are good kits. Quality + cheap do not exist in the lifted truck world hahah.
2001ram15004x4
Thanks a lot for the help guys! With a 5 inch lift and 35s will the wheel wells look stuffed? Or some room
2001ram15004x4
If I did a 5 inch skyjacker lift and 3 inch body lift.. Will the bumper brackets for the front and rear work with heavy steel off road bumpers? Will they be compatible with aftermarket bumpers and can they hold the weight?
Johnn123
Ontario
I'd just skip the body lift.
Johnn123
Ontario
Will it put a lot of stress on the front end or something?
Yes. 2G Ram 1500s use the Dana 44 front end, which is notoriously weak for a truck front end. Ball joints, track bar, wheel bearings, tie rod ends, etc will become yearly chores, if not more. Also very hard on the transmission if you have the stock ratio.
2001ram15004x4
So best to stick to a 12.50 35 unless I want to change the axel and get new gears etc.. I've got the 4.10 gears right now
Johnn123
Ontario
Oh I was not aware you had 4.10, I was assuming you had 3.55. Majority of these rigs had 3.55. 4.10 will make life much easier on your trans. What's this truck mainly do? Daily driver? In town, highway? 35's regardless what width will still be very hard on your front end.
2001ram15004x4
It's my daily driver and i drive it both in town and highway about 50/50. What if I stayed on 33s until I can get a Dana 60 front axel. At the moment I have a ranch hand front bumper do you think that's ok or too much stress on the front end because of the added weight
Johnn123
Ontario
Personally I was a fan of 4.10 and 33's. I'd just stick to that. The ranch hand is heavy yes and it will add stress.
2001ram15004x4
I found a Dana 60 for the front but Id have to put the 4.10 gears in it but I could keep my rear axel because they are stronger right?
ChloeBrooks
