help 2013 s&b intake
california
I installed s&b intake today on my 2013 1500 hemi
I cant bolt the ac line backas it hit the scoop the only way i.can bolt it on is if i loosen the air box from where the oe bolt sits but dont want it all lose so i just left the ac line as is but it it sticking up a bit doesnt hurt hood at all but dont like the way it looks is this normal or did i do something wrong as i followed the directions as i received them??and should i also leave the scoop open from the bottom or closed?
And i also have a throttle body spacer airraid thati bought from.a friend is thateven goodat all or should i remove i dont want to be putting parts that will cost hp lost help will really be appreciated?
URdone21
CA
2013 Quad Cab
I had the same problem with the S&B CAI install when I got to the ac line step. I had to leave that part unbolted right above where the factory air duct is. I don't know what to do with it other than leave it unbolted.
Leave the bottom air scoop open.
If you already bought the space and can't return it, install it. Easy install.
california
california
Yeah i guess i leave like that for now
So does the spacer do anything?
My next mod would be a bullydog tuner and 87mm tb
TXKID
Houston, TX
No the spacer won't do anything
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Throttle spacers are a waste of money. :jester:
Ported Throttle Bodies however are da bomb! :happy3:
URdone21
CA
2013 Quad Cab
Guys, he already bought the spacer. It's not going to negatively affect your engine performance. Install it.
california
california
To bad for me but i guess i should of. Asked before we learn somehow lol
And yes i heard the ported bodie is reall good will be getting that for sure in the future but what is the difference between the ported 85mm and the 87mm?
shawnb1043
Gonzales, LA
From what hemi450hp told me the only way youll feel any difference between 85 and 87mm is with headers.
california
california
i see good to know
and about how much hp do this ported bodies give you ?
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
i see good to know
it will vary depending on how much performance things you add to the truck. The more performance goodies you add the better that TB is going to get.
glsander
