Help a crackah out!
tommyboi87
houma louisiana
5.2 Magnum
Noticing a bit of negative camber on the front end. A bit more than I should have from lowering the front end. I do need upper and lower ball joints and tie rod ends I believe. But my biggest question is, which of those is causing the negative camber? Control arm bushings are fine. I just don't know which I should change first.
Merc225hp
NA
truck
gas
Change out the Bj's first as the tre's have nothing to do with camber.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
I appreciate it as always merc. You're more helpful than a little bit man.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Hey Merc, when outer tie rod ends are starting to go out, do they start to make a "clunking" noise? I've been hearing a clunk from the front suspension on take off and sharp turns.
Was not set from an iPhone.
