Help identifying lift height
Usa
Hey guys, first post here!
Just bought a 4th gen 1500 from a dealer and I'm loving it. However, it came lifted and I'm just trying to see if anyone can give me an idea of what size lift kit it may be, I'm totally new to rams so sorry for my lack of knowledge.
For reference the truck is sitting on 20's with 275/60r20 fallen wildpeak at3w tires at about half tread.
https://imgur.com/a/vTxuQzl
Thanks for the help!
crazykid1994
Looks like a leveling kit. If you go to the front struts you can see if it has a spacer mounted at the top of the strut or see if it’s an aftermarket strut. Post a picture
B
Usa
I'll check the strut tonight. I'm so used to looking at the spring and seeing if there is a spacer so that's what I've been looking at.
I thought it may be a leveling kit but wasn't sure since the rear still sits a tad higher. Anything I should look for in the rear?
crazykid1994
Post a picture of the rear spring as well as top and bottom spring perches. Could be spacers but given your picture it doesn’t appear that the rear is any higher. I’m running lift springs front and rear with 35s on my truck. Bilstein 5100 front adjustable struts as well. I do not have stock photos unfortunately for you to compare to.
crazykid1994
Found one. This is just a leveling kit with 275/60r20 tires
olyelr
Kewadin MI
Looks to me like a leveling kit up front, with a spacer out back. Theres just too much rake still to not have some added lift out back (if its leveled up front).
this pic shows it well, as you can judge by the center body line. The front tire is definitely sitting up above it more than the rear...
