Help! OEM Foglights 2021 Warlock
ntmd8r03
Colorado Springs
This week I installed OEM Foglights (part# 68466268AB) the Fog Light Jumper Harnesses 68154309AA and 68197065AA do not work with the foglights for a Warlock the connectors are for halogeon bulbs and part number 68466268AB are LED. With the help of the parts guy at my local dealer we tracked down part number 68271557AA. Part number 68271557AA is listed as Front Fascia Wiring. The diagram does not properly depict the part as the diagram depicts a harness with connectors for parking sensors, but the actual part does not. I purchased the Foglight Extension Harness from M2 Mods, and wired it up per the instructions (easy enough to follow). I made the correct changes with alfaODB, CBC Config I/O-Connector A Pin 01 and Connector D Pin 13: Front Fog Lamps Output Present -yes, CBC Features-Front Fog Lamp Dropout Enabled - yes, and I set CBC Features-LED Front Fog Lamps Present - yes. The fog lights do not turn on. I get the indicator on the dash that they should be on, I have checked the voltage at the connectors and I have 13+ volts at the connector. Is there something that I am missing with the factor LED lights? The Hi-beam dropout works as it should. Any help is appreciated.
Administrator
try turning the truck ignition on but don't start the truck and see if the fog lights work. If there is a problem with the bulb out detection, this should bypass it.
N
ntmd8r03
Colorado Springs
Just tried it, no change. Thanks though.
michaelw31
NJ
3.6L
How do you actually install the lights themselves? Did you remove the lower bumper or did you work your way through the wheel well?
I removed the grill and saw what appeared to be mounting brackets behind the bumper but I had no way of getting in there. It seems to me installing the lights will be more daunting than wiring them.
Mb7640
Fountian hills az
I just installed mine. Yes you have to remove the bumper but it's very easy. I did it by myself here are some pics
jeanbacan
Alberta, CA
V8
@ntmd8r03 Hey, have you found the correct jumper wire for led fog lights 68466268AB? It seems 68271557AA would not fit them as @Mb7640 mentioned. I mean, imagining such a wiring exists to connect to m2 harness. Im not willing to replace the connectors as Im very beginning in changing anything on the car so I dont have the experience. What I could do is order 68271557AA and then use an amazon cheap led to replace the bulbs.
Hydra21Warlk158
Pennsylvania
I have 2021 Warlock that didn’t come with Fog lights. Got all the OEM parts necessary and installed then but, can’t find the connection from body to make them work. Do I need another part? Does anyone have a pic?
Mb7640
Fountian hills az
I used a auxbeam switch panel for mine and I use it for my light bar
Jaketeady
Canada
Hey
Will you sent me where did you buy your fog light I have 2021 ram warlock please and thank you and what is the parts do I need and also if you have a video how to install it so much helpful thank you
RamDiver
Marlborough, Ontario, Canada
Hey
FYI, the OP'er hasn't been online in about 9 months.
