Gordo2212
- Aug 23, 2021
- 244
- 122
- Location
- Mississippi
- 2018 3500 Tradesman
- 6.4 L Hemi
Yesterday I switched out the HCU for ABS system on my 2018 3500 6.4l. I did the initial bleed then ran the ABS bleed in Alpha. I expected to have to open all 4 valves but it only did the passenger front and rear. I did it twice to make sure I didn't screw it up but started on front right then went to rear right and said completed successful. It definitely did a good job bleeding that side out. I went to driver rear and front and started to bleed with hand pump and did not see any larges bubbles coming out so seems to be ok. Used three 12 oz bottles of DOT3 to keep reservoir filled.
Drove around today and breaks work fine, just doesn't seem as stiff as it was before. Start feeling breaks maybe 3 or 4 inches after touching them. Could that be just because I installed new HCU and system not fully pressurized?
I also couldn't get truck to start after installing new HCU. Found code C0020-01 in there for "ABS pump motor Control-General Electronic Failure." Cleared that and it started right up.
Anyone have some insight who has done this before? Thanks.
