Help with my a/c please
iJacob
So I got a recharge kit and went to use it and it says on the guage its over full. But the compressor keeps kicking on and off and the ac is still warm... Please help????
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
It's probably just air causing the pressure to read high. The system should be evacuated, have leak detection dye put in, and recharged. Run it for a few days and then check for a leak with a black light. If you don't have a way to pull a vacuum on the system, you'll need a shop to do it for you.
nussdawg395
PA
5.9 Magnum
Is your condensor fan turning? It should be on at any ac setting and if your little electric fan is out you wont get ac at idle and your compressor will keep cycling. This is a pretty common thing to go on these trucks i've found as mine is out also. There is a replacement motor you can put in the shroud.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Do you have it connected to the low side pressure? If you are onvthe high side it will always show over full
Sent from my liberty x!
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
This is true if the engine is running and the compressor is engaged. With the system off, the pressures should equalize unless there is a blockage in the system.
iJacob
iJacob
Well isn't the low the closest to the windshield on the left looking in to the truck. ?
txbass06
NE Texas
5.9 Magnum
Most recharge kits you get from a parts store will only fit on the low side port. You didn't have to force it over the port did you?
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
The low side is the smaller of the two A/C ports so you can't hook it up incorrectly.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
^If there is a will there is a way, working at a dealership ya should know that.
txbass06
NE Texas
5.9 Magnum
Unfortunately, I do. It usually involves a customer that is dangerous at best with tools.
I see it happen a lot working at a parts store. Usually on $1000 cars with $6000 worth of rims...
Sent from my iPhone 4 using Tapatalk
iJacob
iJacob
Yea my ac reacharger only fit over one and the cap said L on it I'm sure that is was the right one .
Sent using taptalk on HTC EVO 3D
iJacob
iJacob
Problem solved: hit my condencer fan with hammer then it worked... Been working since
reefguy89
laurel de
^^ haha nice when all else fails just hit it with a bfh
nussdawg395
PA
5.9 Magnum
haha told ya lol. jk glad you got it straightened out man
