Help with P0455 fault code.
Samxboy1
SW Florida
So I've replaced the purge valve, leak detection valve and the gas cap and still getting the P0455 dtc
What else could be causing this? Any ideas please
Dark Knight 500
Alberta
Next step would be to replace the ESIM(Evaporative System Integrity Monitor) located on top of the charcoal canister
OCDTech
Louisiana
Isn't that what the leak detection valve is? Or something different?
S
Samxboy1
SW Florida
Yes I believe you're right. I've already replaced this. I'm now getting P0456 which is a small leak. There is a very faint smell of gas from the filler cap area, but it's a brand new Mopar cap. I've gone through every connection in the EVAP pipes. The truck is a 2015 with only 50000 miles. It does however sit for several weeks/months at a time in the hot florida climate so it's tough on rubber etc. I did hear there is a PCM update available that reduces the sensitivity of the system so reducing the likelihood of error codes occuring? Has anyone had that update done?
56PW17
Pa
I think this was the same code I had when my tank/ roll over valve was cracked. If you have a gas smell have you looked at the roll over valves?
I had a gas smell towards the rear of the cab
