Austinbeck0426
2013 Ram 1500, 5.7.
-When driving, doors will not lock automatically.
-Will not lock with keyfob, but lights will flash and horn will honk as if it locked.
-Will not unlock with keyfob if doors are locked manually.
-Will not lock or unlock using door buttons on both driver and passenger side doors.
-Scanned the door modules will scanner, both modules are good.
-Checked fuses, all good.
-Checked wiring, all good.
-Under the dash on the driver side, you can hear clicking, which has always been normal, pcm engagement. Still hear the clicking when using the fob or door buttons, but none of the locks react.
-All windows and mirrors still work off the driver side control panel.
Based on every forum I’ve read, I’ve checked everything suggested, and still haven’t found a solution.
HELP.
HELP.
