Hemi 5.7 bogs and dies
neverlift17
its a 2005 ram hemi 5.7. when i slowly press the gas petal it will bog or die. if i blip the throttle it usually acts fine we just drove it today and everything was fine. its random as well.Any help would be greatly appreciated
MADDOG
Living in a Firepit
6.4L HEMI
I'd start with the easy stuff. Clean your throttle body and check your EGR valve.
Any codes?
N
neverlift17
alright, no codes as of right now. i will check the gorunds i searched the forums and seen a similar problem and it was a ground. the truck was recently purchased last week from a car lot so who knows about the maintenance, however there are new pulg and wires in it.
i thought maybe a vacuum leak or egr but if its the ground hopefully i can find it. the thing i dont get is that 2-3 prior to it stalling it was running great
N
neverlift17
it starts and idles fine but once the gas pedal is lightly pressed it dips and rises and if i hold it there it jumps areound. If i floor it it will rev normal
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
The vacuum sounds like a good thing to check too. Never know.
N
neverlift17
thats what were doing now, the long term fuel trim will drop to -32.8 at time as well as the other fts bounce around between -3.2 and +3
N
neverlift17
got a code for catylitic efficiency and an 02 sensor 02 voltage was at 3
