HEMI Tick - Only A Matter of Time
jmd4100
US
I bought my 2007 1500 Hemi with 130k miles. Orig. head studs/bolts. Figured it was only a matter of time before I’d get the all-to-common tick... well, as of yesterday, it showed up. I only see one bolt/stud left on the whole left bank. Does anyone know if i can just rethread or restud the heads instead of buying new ones? Or is it better to get new heads? Thanks
chrisbh17
I would only expect do heads if the stud holes are so rounded out that the new ones wont fit in.
Carefully remove the studs any which way you can, use a thread cleaner (kinda looks like a dull tap with a flat end) to clean the threads and reinstall new studs.
jmd4100
jmd4100
US
Great thanks!!!
ramportin1
Sickest member here
Oregon
And that's not what the hemi tick is, btw
Sent from my SM-G975U using Tapatalk
southalum
