LeesEvoX
- Oct 29, 2017
- 1,652
- 2,216
- Location
- Houston, TX
- 2020
- Hemi 6.4l
with a pushrod motor you don’t have complete control over the valve train (the hemi has a little). On a DOHC motor you have a lot of control over the valve train with the cam gears that’s how they can do a lope tune. Also on a DOHC and a OHC you are limited on how much overlap over lap you can have due the physical room of the head also your cam gears will take a lot of the chop out- you can actually lock the cam gears for chop but will lose a lot of horsepower. example 5.0 mustang with a stage 1 cam set you will loose 100 horsepower by locking the cam gears!
Ahh ok. so reading this, it is to do with the cam phasers, like how Mitsubishi has MIVEC, and Honda has Vtec. they can change the cam profile for low rev, low end torque, or high end, high HP.
Whereas the Hemi would just have a cam gear and chain, but no phaser on the cam.
So the Hemi must have some sort of phaser on the cam gear, because we have MDS right? I am going to look more into how the MDS works exactly. Would be cool if you could manipulate the cam phaser for more lift or duration on these trucks. But im sure FCA made them to NOT work like that lol.
Anyway, thanks for the knowledge!
