Horrible Vibration
2011Ram1500DOwens
2011 Ram 1500 quad cab, 4.7, 67K miles. New Tires about 3-4 months ago with an alignment. and a rebalance about 3 weeks ago, maybe a little longer. Buy a Ram dealer. Still has a horrible vibration, notice it really bad between 55-75mph, can feel it in the steering wheel, and then you can't hardly look at a mirror without almost getting nauseous. Any suggestions? Have somebody else look at it?
R.L.K.
Bristol , Tn.
Do you have a lift or a level ?
R.L.K.
Bristol , Tn.
4x4 or 2wd
R.L.K.
Bristol , Tn.
Did you have vibes befor the new tires
Pull Ya
Cedar Creek, Tx
One or more of the tires could be out of round or you may have thrown a weight after they were balanced. Re-balance and have them rotated and check front suspension to see if anything is loose.
Jay
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
2wd, no lift. I didn't notice it prior to the new tires
Who installed the tires and is warrantying them? Sounds like they need to road force balanced.
Even with a road force balance, they may still be bad. I went through 2 sets of BFG's on an older truck to get the shimmy and shake out of it. Sometimes a crap lot of tires make it out the plant.
Good luck.
2011Ram1500DOwens
Good luck.
I bought them from Bob Moore Chrysler Jeep Dodge Ram, in OKC. So, I guess they hold the warranty
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
Well any tire retail seller that is licensed seller of whatever brand you had install technically can provide warranty service but most will kick you back to the selling business.
This is where new car dealership that play "retail tire seller" on the side can get you into trouble if they do not want to go the extra step to resolve the issue. If they push back, you may need to contact the tire manufacturer direct and explain your issue to see if you can have another authorized tire retailer that is actually their day business of selling and installing tires to see if they can help.
Was this something you notice right after getting them installed? If you have driven months or so with no report of a problem. The installing dealer may waffle and blame your vehicle.
