How do they do offroad?
fadetoblack188
I just got a 2014 crew cab 5.7 hemi 8 speed express.
I go hunting a lot with some other guys and somtimes we take some fairly rough trails heading in. Sometimes a foot of snow uphill. Sometimes mud, dips , rocks
My question is will the truck perform ok under these situations?
The two other guys have a 4 runner and a sequoia. Just want to know if I can follow the pack in :)
Thanks
Cthulhu
Calgary, AB
Cummins 5.9
You need to keep in mind your likely longer than they are. So turning is going to be challening, as is obstacles. It'll be easier to get high centered as well as your going to be wider... so, depends on how your going to lift/modify the truck to improve your approach/departure/clearance angles you may be able to keep up with them... but do you want to destroy a nice vehicle tryìng?
Sent from my GT-P5210 using Tapatalk
Cthulhu
Calgary, AB
Cummins 5.9
On that note as well, when I was in the Canadian Forces, we had Bombardier Iltis's that were supported by chevy 2500s and as under powered and crappy we thought the iltises were, they ran circles around the chevys.
JJP71584
Pgh, PA
I also hunt in the mountains, dirt roads, muddy fields, etc...here's what I would recommend, a 2.0 level and a good set of A/T tires..then it would be great. On the stock Goodyear tires, it will still do decent, but you'll see the limitations quickly...IMHO
Sent from my SPH-L720 using Tapatalk
aplineman
Your front bumper is going to be the biggest issue, then tires.
F
fadetoblack188
i guess we will have to see when the time comes.
arod412
Philadelphia
Tires man.....if ur gong to run factory in the truck, personally the tires are crap. Just shop for tires right now.
Angel
"worrying about MPG in a truck is like looking at a Prius tow rating"
Arctic-Rodz
RGV, TX
6.7L Cummins
Angel
Those stock tires are pretty good in the sand though
arod412
Philadelphia
I year ya..... I still run them after 16k miles. If I had the money, I'm replacing them. I notice in the snow, they don't grip as well, sometimes I have to put it on 4x4 when I know I can make it without it, and when it rains lightly, it slips a little. They are just "ok" tires in my book, but if you are going to do off roading, your going to need something more aggressive.
Angel
BlkRamRt
SoCal
HEMI 5.7
is your truck 4x4? like mentioned above i would get some better tires so that you can catch better grip in the harsh enviorments. just my opinion. take some ropes or something just in case you get stuck....lol
Arctic-Rodz
RGV, TX
6.7L Cummins
Thanks
The truck itself does well, limitations are the tires. Suspension and the activation of the 4x4 system works great in my book.
For mud/rocks I would get a really good all terrain. The OEM tire is decent and as I mentioned has worked really well on the sand since I go to the beach a lot.
But as soon at these wear out im gonna get some Nitto Terra Grapplers in 305/55R20 :D :rockit:
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
Tires tires tires! That and what was previously mentioned, tight turns will not be as easy if the other trucks are shorter.
F
fadetoblack188
id love to put the nittos on... but 400 a tires.. geez i just got the truck lol.. not ready to spend that.
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
I hear ya, when tires started getting more expensive, burnouts became a thing of the past for me.
arod412
Philadelphia
Lol.... when your dropping over $1k... it makes you think twice but in ur case, it will be worth it.
The stock tires will barely keep up, but with better tires, u would lead the pack...lol.
Try it first couple of times just to see.
Angel
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
I don't think that they list for $400, but after shipping, mount/balance/taxes, it's probably getting close
pickupman66
Tennessee
wow my last set of the NItto's went for about $180 a pop. granted that was on my tundra with 18's
F
fadetoblack188
yeah the nitto terra graplers for 20 inch rims are priceyy
