vhmike73
- Aug 13, 2015
- 199
- 143
- Location
- Watervliet, NY
- 2015 2500 Laramie Limited
- Hemi 6.4
As an aside to shipping woes, cold weather and sourcing pins/connectors, I have a question about installing the door antennas:
Would there be any reason why installing the door antennas into the B pillar on a Crew Cab wouldn't work? It seems, given the apparent difficulty of running wires through the cab/door connector, that the B pillar would seem to be easier to access, and certainly would be simpler from a wiring perspective. I've yet to pull the lower pillar cover off the truck (or ANY cover for that matter), so I don't know what's behind the plastic (besides the lower seatbelt mounting point and retractor mechanism) that would be either conducive to or prohibitive to using that area as the mounting location. I'd doubt reception is a prohibition, since the wiring diagram calls for these to be mounted in the rear doors, but I'd like a consensus answer!
A secondary question on the mounting: did you guys who installed these in the door screw the antenna to the carrier plate? Were there clearance issues behind the carrier plate? If you mounted the door antenna elsewhere, did you use screws or 3M double-sided tape? Physically mounting in the B-pillar might be easier if the shape of the pillar would allow for using 3M tape (and adhesion promoter with it). I know Jimmy07 used 1/2" self-tappers on the back wall, and I'd guess I'll have to see what the ORC bracket in my center console has for screws, so the front/rear antenna install locations are clear to me. Just wondering about those door antennas.
Thoughts?
Thoughts?
