How To: Add Factory Keyless Enter N Go
vhmike73
Watervliet, NY
2015 2500 Laramie Limited
What gauge wire did you end up using ?
I will crimp some on the gauge you used if possible and take a pic of it etc if it helps you
Skuppy069: if he's using the same wire that Jimmy07 linked to on Amazon, it's 24ga twisted pair.
I was having the same problem with the rear "support" crimp (which is supposed to grab the wire sheath) not crimping very well. Either it would bind more flat than round, or a handful of times it cut the whole pin off. I did cut off the rear parts of the pins and bent them to make more of a "U" shape, which helped. Now I have to wait out the cold; I can't pull the truck apart in single digits!
skuppy069
canada alberta
2018 1500 cc
I was using 20 awg and had to trim the tabs so I can only imagine on 24awg
fearroyo
Tampa, FL
EcoDiesel
A lot crimped more flat than round around the wire sheath.
markatmjm
Chicago
The remote starter kit didn’t come with a RF hub on my 17. The only thing that you pay for with remote start is the keys, the new hood latch and wiring that goes to hood latch.
How much was the remote start in your case?
markatmjm
Chicago
You’re showing that you have a 2016. I’m NOT certain that a 2017-2018 hub will work in pre-2017 trucks, but it could be a possibility if you’re willing to take one for the team. I pondered that in this post
https://www.ramforum.com/threads/how-to-add-factory-keyless-enter-n-go.134961/page-4#post-1932825
As far as remote start, that’s a whole other subject. Start off setting yourself up by getting the fob I linked at amazon that already has the remote start button. Then you’re going to have to do some exploratory work on seeing exactly what wiring you have or don’t have for the hood latch sensor. Read through this thread and you will have a handle on identifying whether or not you have that wiring https://www.ramforum.com/threads/hood-latch-assy-for-the-remote-start-kit-wiring-question.133266/
Ok I read both threads.... great info.
Just to clarify if I get the 2017-2018 hub for my 2016 Ram 1500 ( I’m willing to be the Guinean Pig and do the test)
If my keyless and go can be programmed successfully with 17-18 RF Hub will I be able to ad the remote start as easy as the other members did with proper remotes and grounding the 11 pin for the hood latch and enabling it with AlfAObd or will not be possible to ad remote start?
kp4243
NC
I want to say it was just a little less than 200 but I don’t remember right off hand. I got the back up camera and it from the same dealer. If I can remember who it was I will let you know.
J
Jimmy07
If you go through with the keyless enter n go with the 2017-2018 hub, and it works, then you will be able to add remote start also. Just enable all the remote start settings while you’re enabling the keyless go and passive entry settings. You will already have the correct remote (assuming you get the one linked on amazon in the write up). The absolute easiest way to get remote start working is to throw one of these terminals https://www.mouser.com/ProductDetail/829-13627884-L?r=829-13627884-L in with your harness parts order. This is the terminal for pin 11 on that BCM connector. Crimp it on to a length of wire, insert it into the BCM connector pin 11 (if there’s a wire there, remove it), ground the new wire, and that’s it.
So in all, these are the settings you’ll enable before you start your install:
Keyless go present- yes
Passive entry present- yes
Fobik safe enable- yes
Passive entry CSM- yes
Remote start present- yes
CBC I/O hood ajar switch input present- yes
CBC I/O usage hood ajar switch usage- 500 ohm series and 500 ohm parallel resistors
markatmjm
Chicago
Sound good I will order all of the parts needed and the 17-18 RF hub and see if it will work.
In case it doesn’t work I will order 2016 RF Hub part number specified in the thread and then enable the same futures and ground the cable pin 11 and I will have remote start working as well?
Reactions: kad
J
Jimmy07
For a 2016 hub, you would also need the remote start antenna that plugs into the hub.
sawz
Centreville, VA
2015 Ram 1500 QC
Great information! Thank you for taking the effort to figure this out and provide the information to the group.
One quick question: Do you have the pin part numbers for the door connector? I'd like to pin it through the connector if possible instead of running the wires through it.
J
Jimmy07
The reason I abandoned this idea is because there are two separate connectors for the wires going from the cab to the front doors. The connector for the driver side is there, and has enough available positions to pin, but the passenger side connector is not present because the only two wires it carries is the door handle sensor wires. I could find the terminals to buy for both halves of that connector, but I couldn’t find the connector halves to install on the passenger side in stock anywhere. The other connector on the passenger side doesn’t have enough open slots for the four wires. Here’s the part numbers in case you’re able to source everything:
Yazaki 7116-4110-02 is the body side terminals
7114-4110-02 is the door side terminals
Yazaki 7283-6468-60 is the body side connector
Yazaki 7282-6468-60 is the mating door side connector
Positions 2, 4, 11, and 12 should be empty on the driver side.
chrisbh17
When I attempt to install the handles I am going to try and see if there is room for the antenna behind the lower B pillar cover. Makes it a lot easier to wire and the antenna will end up in about the same location as factory so there should (hopefully) be no range issues.
Ive had the pillar cover off before but I didnt take pics so Im not sure there is enough room, but I figure its worth a look.
J
Jimmy07
I wouldn’t think so? Here’s a visual representation.. Edit: Actaully, the passenger front looks like it could be placed on the driver rear and driver front on passenger rear but you would have the cylinder on the passenger rear.
Is this a severe optical illusion, or are your handles not all the same size?
Both front and rear passenger side handles are oriented the same with the metal piece that accepts the rod in the same spot. The only way I can think to get a front passenger passive entry handle on the rear driver door is to remove that metal piece that accepts the rod from the existing rear driver door handle and install it in the correct spot on the new one. wZwnzD5.jpg
chrisbh17
The pics on AuthTech's website also make the rear handles look smaller, but I wasnt sure if that was just them with a bad pic or if they were actually smaller.
And Im still curious what handles they actually sell, since it doesnt seem like the RAM was ever available with rear handles that have the small lock button built in.
Ghost_RAM
VA
It’s just an optical illusion. Here is a pic of the passenger front and driver rear. I’m not sure anything would have to be done? They look identical other than the passenger front having passive entry.
Ghost_RAM
VA
chrisbh17
I just sent AutoTech and email asking what handles they are providing for the rear.
The image they have shows no keyhole on either rear handle, it does show the lock/unlock button and they do look shorter than the fronts. Very curious if they are using a different model vehicle for the rear handles.
kp4243
NC
So if you are doing 4 doors. I take it that you can swap the chrome part out of a passive entry handle onto the drivers rear existing handle to get rid of the keyhole??
