How to add remote start to 2017 Ram
HarryS
Air Force
Clovis NM
Ok, I'm confused. The wiring diagram shows two different pinouts for the hood switch, one with wires going to the PCM (remote start) and one with the wires going to the BCM (anti-theft). Anti-theft uses wires at 5 and 6 at the front module connector, and the 'remote start' has wires at 25 and 30, on the same connector. This is for the 2014Screenshot (264).png
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Ok, I'm confused. The wiring diagram shows two different pinouts for the hood switch, one with wires going to the PCM (remote start) and one with the wires going to the BCM (anti-theft). Anti-theft uses wires at 5 and 6 at the front module connector, and the 'remote start' has wires at 25 and 30, on the same connector. This is for the 2014View attachment 579563
The wiring necessary goes to the BCM. I would disregard anything you currently have diagram wise and go off the info in this thread. I have a 2014 and used the info here to get mine working.
HarryS
Air Force
Clovis NM
Thanks.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Fyi:
the wiring from the hood latch to the inline front-end connector under the PDC goes through either pins 5 & 6 on 1500 ( or 1 & 2 for 2500/3500) on the way to the PDC. (Ignore the start/ stop stuff)
Could be missing from the latch to the PDC and/or from PDC to BCM.
HarryS
Air Force
Clovis NM
Fyi:
the wiring from the hood latch to the inline front-end connector under the PDC guess through either pins 5 & 6 on 1500 ( or 1 & 2 for 2500/3500) on the way to the PDC. (Ignore the start/ stop stuff)
Thanks. My front end connector is wired for 5 and 6.
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
After reading this thread, first and last page, I am praying to a higher power that my truck came with the click your heels three times method to remote start my truck.
( hit the lock button not your heels)
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Probably not BUT you don't need those harnesses to enable it. If you want it like factory @Mpgrimm2 sells a harness for it.
Steves2024RAM
