I finally finished activating the Remote start on my 2014 1500 Express today. Works perfectly!
I activated the Remote Start on the existing RF Hub and BCM, I did not replace the RF Hub. My factory RF Hub is a 68213675AF. I had my PIN number already from adding a key a few years ago. (My dealer provided it with no problems).
I replaced the rubber button panels on my existing keyfobs with the ones below from Amazon. They fit perfectly, look great and work better on all the buttons than the originals did.
www.amazon.com/gp/product/B017MVAO6Y
I replaced the hood latch with the OEM one with the switch. Part # 68159725AB. I could have gotten an aftermarket for half the price, but I wasn't willing to risk it on the part that keeps the hood from popping open going down the highway!
My truck already had the wire from the latch to the Front Body Connector under the TIPM, so I just needed the short harness from there to the BCM from
@Mpgrimm2 at
M2Mods . The one thing I would do slightly differently if I had to do it again is that I'd spend the extra money and get the longer version of M2Mods harness that runs from the latch directly to the BCM, bypassing the front body connector. (You were right M, getting at that connector past the TIPM is a PAIN!)
Since I didn't replace the hub with one with a seperate antenna, I'm not sure on the range yet, but since I know I can lock/unlock it from inside the house, the range should be plenty.
-K
