How to convert 2017 8.4 NAV to carplay?
bloup
Hello it's been hinted on this forum that the Uconnect 2017 8.4 NAV can be converted to the 2018 radio.
Can someone point me to what parts are required or post that details the process?
And is this mod applicable to Canadian radios?
Thank you
p.s. I'm not talking about replacing the head unit, that's been well convered.
18harvest
huntsville
I think on you tube there's some mirroring type devices.but other than that no true way to convert ra radios to carplay/auto.
MidTennMtneer
Princeton, WV
Pentastar
By convert he means change out the radio to an ‘18.
The software capability just isn’t there for CarPlay with the older radios.
B
bloup
Seems odd he would only specify the 2017 and not 2013-2017. I also recall seeing a European web site replacing an internal module in the RA4 to get Auto but I cannot find it anymore.
CuylerTech quote post #6 "Just figured i'd drop off my 2c as I was the first one to put one of these radios in a ram. The heated seat issue carries over to 15 also, not just 13-14s. The Durango Mount with a 30 second cut with a dremel will mount up fine using 2 screws in a ram. 2017 radios can be converted into 2018 radios. I have 3D printed adapters to use the 2018 Hub in a 13-17 lid with slight dremeling but will fit and look mostly stock."
18harvest
huntsville
The module thing you are talking about is what I was talking about. in the video I saw it just basically mirrored you phone and didn't work as smoothly as a dedicated carplay radio.I know what he posted but sometimes people inadvertently get things wrong or misspeak .as far as I know you cannot adapt a Harmon radio to carplay/auto.you will have to switch to a uas/uaq.I like the harmon radios 1000 times better than the Panasonics so i wish there was a way.
B
bloup
Ok me sad
Anyone did the jump to 2019 12" 4C screen?
If i have to buy another screen why not a 12".
B
bloup
Yes it would make financial sense to get a new radio.
Anyone tried a 12" screen from a 2019? I'm aware i would need the UAQ module also.
B
bloup
I found a really good deal on a 2019
Uconnect 8.4 4C
Anyone went from a 2013-2017 RA4 to a 2019 4C ?
B
bloup
18harvest
huntsville
no 2019 5th gen radios will work.a ram classic radio will work.i tried a delphi it fit and powered up but 90% of the functions didn't work.and i would strongly suggest if you get a uas or uaq that it has a ram part number.the only radio from another vehicle that i can verify works as intended is from a 2019 compass and i don't remember the part number.even though it worked it had 5 different vehicle icons you could use on the nav screen.so even it was different from a ram specific radio.
B
bloup
Thank you for the clarification. I will go with a 2018 4C UCQ for Canada. I guess I could try a UAQ from US but I would need the 911 harness and I'm not sure I could get HD Radio and XM traffic link fonctional so why bother.
Ram2018
Columbus, Ohio
5.7 LITER V8 HEMI ENGINE
I just bought a 2018 RAM and MAN I WISH I could drop the 2019 12" 4C screen on my 2018 Ram...
Has any one successfully been able do this yet?
Fatboy1989
