SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I'm not paying for any XM. Just curious how long I have left if the subscription. I bought the radio brand new. I will call them tomorrow
I don't believe the new "radio" comes with a subscription but rather the new "truck".
You should be able to access SXM though by a phone call. If your truck has an active subscription it can be transferred.
Austen
Missouri
OK I got my SD/USB/AUX hub today for the 17 Challenger Part# 68294633AB that Cuylertech referred too, plus my harness from M2mods arrived today as well. Absolutely beautiful work guys as usual! The hub appears to be the same size as the Ram UAS/UAQ hub so I am hoping if I can find the storage bin for an 18 Ram this hub should be a direct fit. My truck came with the RA2 but it shows the SD card option on the UAQ/UAS radio because I actually activated the code in my BCM. I'm hoping it will work. I might try to install it tomorrow depending on the weather. I am borrowing STecoD's spare UAS until my UAQ gets here just to test and see how everything works. I will report back with any information. 2987a7cf1c99b1a02afee329ec266159.jpg83510fe20a4e2cdf2b0aea1df032aaf4.jpg
Sent from my SCH-I545 using Tapatalk
What did you go to and turn on to enable the SD card on the radio?
Austen
Missouri
What do I go to and turn on in the BCM to enable the second USB to show up on the radio with the 18+ media hub?
duunoit
EcoDiesel
Not sure exactly which one (probably Aux + USB + extra USB), but it's in ECUConfig 3-External Port Type
StingRay
6.7 Diesel
Anyone have a manual for these UAQ radios?
I downloaded from RAm owner’s manual site. Selected 2018 Ram 2500, then under Additional Resources pick list the 4C/4C Nav is there.
Austen
Missouri
Did you replace the ac outlet that was there? Also will it work with CarPlay?
How did you wire the media hub into that cubby? I really like that idea.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
I bought this: https://www.amazon.com/gp/product/B01N66N1JK/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Wired one to the cigarette lighter USB charger and one to the media number in the arm rest.
What if you could plug that directly into the extra connector on the back of the 2018 hub. Hmm? ...
StarTech.com 1 ft Mini USB 2.0 Cable - USB A to Mini B F/M https://smile.amazon.com/dp/B004ZMYEMY/ref=cm_sw_r_cp_apa_i_bE4LCbYFTK2FK
Recent bought my wife a 2018 Jeep Compass with the separate rear USB port plugged into the front hub that way (I need to take her console apart to get the harness and secondary hub OEM PNs)
M² Mods.
drozek
Streamwood, IL
drozek
Streamwood, IL
M² Mods.
It didn't work, so I thought I saw some where the pin out of the media hub conversion cable I bought from that guy, you told me to buy it from you have it handy? I was going to splice into that cable and see if I can get it to work.
Mpgrimm2
SC
5.7L
There aren't any active USB related signals on the USB Hub Adapter harness we make... There's a separate Mopar USB cable between the hub and and radio.
My wife's new 18 Jeep Compass has a secondary USB port (hub) on the back of the console that is plugged into the one up front via a secondary USB cable. I suspect the PNs from those 2 items are what we need and I just need to take her Jeep apart for the PNs.
M² Mods.
drozek
Streamwood, IL
M² Mods.
What signals are coming out out of that cable?
