How to keep Cam in 2025 Tungsden
Ramit355
Minford Ohio
2025 Tungsden 4WD
Hurrican H.O.
I have attempted to keep my Cam on upper rear while pulling trailer. It comes on perfect view but goes off after a few seconds. Is there a way or procedure I need to know or do in order to keep the cam on while in motion longer than the default few seconds? Any help would be appreciated.
Kickboxer
ND
5.7 Hemi-non-Etorque
The system is not made to do what you want.
DanAR
Arkansas
I think you might have to add a separate cam to do that. I believe the system is set up to add cameras like a trailer cam. It might have to be something like a GoPro mount. But what the programming will let you do with full time displaying of the camera, I don’t know.
Ramit355
Ramit355
Minford Ohio
2025 Tungsden 4WD
Hurrican H.O.
DanAR, Thanks for the input. There is two Aux. functions in the set up. This is the First Ram out of the last 5 I have had that actually have a 360 view while moving on all cams 360 and is very useful. I was just thinking maybe there was a setting where I could hold one of them in constant viewing while pulling a utility trailer. I will check out some after Mkt. cams such as you mentioned and see about the confiquration of such.
