Hub Centric Rings
Burstingbb
Charleston
I know our hubbore is 77.8
I am looking at wheels that are 108mm centerbore.
would the hubcentric rings I need have to be 77.8 (Inner Diameter) and 108 (Outer Diameter)?
Dinky
Oregon
since they are made for specific application. i found you order to the specs you need they allow just enough slop to slide in.
JB1
Houston, Texas
You want something around 78mm to 78.1mm, you cant put a 1/2" bolt in a 1/2" hole, there has to be some clearance plus there is a tolerance factor in everything.
buddy guy
alberta
78.1 to 108 if you can get it. i'm sure i've seen that size ring as being very common when i was doing some searching on options. my wheels are 78.1 and allowing for a bit of expansion that's a perfect fit for a 77.8 hub.
Burstingbb
Burstingbb
Charleston
Yeah, all the information is confusing as hell. BORA told me to use 77.8 and even Method Wheels came back and said to use a 77.8. But forums are saying the 78.1, guess i'll order both to be safe
buddy guy
alberta
78.1 to 77.8 is only .3mm. that's like less than 1/10th of an inch for perspective. like i said, just that sliver to allow for expansion. for kicks i looked for a 78.1 to 77.8 hub ring. didn't find one. i suppose one might be made in steel. i can't see one being made in graphite or poly. too thin too stand up. tire place i bought the rims on confirmed 78.1 rims were considered "perfect fit" for 77.8 ram hubs.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
My rims are moto metal and they were at 108, I grabbed 77.8-108 and they fit. It may be the aftermarket rim bore is actually 107.8-9 or something, but listed for buyers to know what to buy?
Kid's HEMI! !!
If u are changing wheels buy them first . I ordered rings before rims and didn’t need to bc wheels came with rings
JB1
Houston, Texas
So I guess you didn't buy the fuel hubcentric wheels after all huh?
