Hub selection help
dekarske
I have read through many posts but still am uncertain on which hub.
My build sheet says 4 wheel abs. But I only have 1 wire on the drivers side that goes to the wheel hub.
Now I need hubs and can't find the one I need.
I'm assuming that the one wire that goes to the drivers side hub is maybe for the cruise control? Because when I changed the hubs before the ones I got had no wire and since then no cruise. Didn't effect brakes at all.
If that's the case, is the hubs that are for 4 wheel abs is the hub I need? And I would only hook up the driver side because that's the only wire that goes to my hub?
Or if anyone has a part number for the hub I need that would be great.
2006 1500 4wd 4.7 quad cab
Thanks to all for the help.
TERRY G ABNEY
Kentucky
You need the ones for 4wd ABS , Napa auto parts PGB PBR930690 , but you can find them anywhere on ebay cheaper just get the ones for 4wd abs,,the wire is for abs but possible could affect cruise control since you have to tap brakes to disengage cruise
