Hvac question
Cts
I have a 14 ram express and I upgraded my radio and bezel to the single zone 7 speed interface. I got the harness from get up kid, but the hvac harness does not fit the module. 8c9935440004c39c61f4e9d57aa05e97.jpg
Sent from my LGLS991 using Tapatalk
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
In case you missed it ....
DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade
(There's also an instruction sheet you can download in post 2)
Basically the 24pin connector doesn't plug into the back of the bezel, only the 8 pin.
A separate HVAC module (must be purchased) plugs into the 24pin connector.
So on the 7 speed conversion harness' 3 connectors ...
24 pin (P1) to existing truck connector
24 pin (P2) to new HVAC module
8 pin (P3) to new bezel
Sent from my SM-G930P using Tapatalk
C
Cts
Thanks
gigabyte3
How did you get a hold of get up kid for the harness? I messaged him from his website a week ago with no reply yet......
Jerzey111
North New Jersey
im planning on doing the same upgrade but i already have 7 speed fan, do i still need hvac module?
thanks im advance
C
Cts
Yep you need the harness and module. Worked like a charm
12sportmc
NC
Your best bet it to go to his website and fill out the request. But here is his email address [email protected]
I don't think he is making harnesses anymore. Lots of people in the radio upgrade stiicky thread have said they can't get in touch with him. There are directions to build your own which are very detailed.
Mahoney419
Portsmouth
HEMI 5.7
I recently upgraded my 2015 Ram 1500 with a 7 speed fan from the 5.0 to the 8.4 with the new HVAC module and wiring harness. The problem I am having is the fan shuts off when put on speed 7 and the A/C does not work (does not blow cold air). Everything works with the old bezel so it must be an issue with the wiring harness or HVAC module. Has anyone run into this issue?
