Hypertech speedometer calibrator
Musky Mike
NC
Has anyone used a Hypertech speedometer calibrator on 2019 RAM? Did it work?
jimh4662
South of Pennsylvania
2019 RAM Laramie Longhorn C.C. Delmonico Red PearlCoat
Yes I have one but I found a better way to change speedometer calibration .
AlfaOBD Software and kaobtech security bypass module/cable.
Plus you can change dozen of settings like have fog lights on with high beams. Do a search on this site for information.
keisur
Cypress, TX
Worked for me. Pretty easy to use too. Tip though, actually measure your tires, don't go off the tire mfr's datasheet for OD. FYI I have a 6" lift with 37" Nitto Ridge Grapplers, had the se setup on my 2013 F150 and had to deal with the speedo being off. This Ram speedo is pretty much dead-on after this correction.
