I stupidly put windshield washer fluid where the coolant goes
Sking80
Atlanta Ga
I opened the hood, saw the yellow cap on the left, opened it and started to pour windshield washer fluid in it. and that is when i realized the other BRIGHT YELLOW cap that has a windshield washer symbol on it. I quickly pulled back the jug, and said the F word out loud. o_O
I probably poured about 1-2 cups in there. Should I go get it flushed right away? From what I read on Google, most says it'll be fine, but some can turn the coolant into gel.
I have done this before so don’t feel bad. I put almost half a gallon of rainx in the coolant. The system is big enough to were that small amount in the overflow will not harm your engine. If you can drain the reservoir and replace with concentrated coolant not 50/50 and you will be fine
Mike Flea
US ARMY VETERAN
Streamwood, IL
UGH
Rain-X comes in 2 different color types
Never use Rain-X on a motorcycle wind screen
Didn't anyone tell you that Rain-X could plug the lines & the windshield washer pump in a vehicle
If you use the wrong color Rain-X, you would be cussing yourself & Rain-X
I've used both the purple and orange, and even mix them on both my Jeep and RAM, ran it in my '99 ZR2 for the 10 years I owned it, ran it in my '96 Ram, never heard of Rainex clogging lines, and haven't had any problems
rustyjonez
little falls
1-2 cups in the overflow bottle you're fine. Assuming this was standard blue w/s washer fluid, it's mostly water and alcohol, which will boil away.
If you filled the overflow bottle, I'd say suck it out with a hand pump, or shop vac or just hose it out with water and replenish with the orange/red liquid gold.
I did it too. 3 years ago. I just drained out as much as I could and refilled. No problems
2020PW
East coast
lmao! I was thinking new brakes and tires for sure.
On a serious note, highly recommend changing the liquid cooled muffler baffle. The heat and washer fluid will expedite corrosion. If it fails you have to replace the cats.
The dealer will argue that you don’t need to, they make ALOT of money off cats. Cats are not covered by any warranty, insist that they change the baffles.
I just had my done on a 6.4 for $150.
DILLIGAF
Canadian Forces
Canada
I started my engine without oil in it for like 10 seconds after my rebuild before I clued in on WTF I was doing. . Hope that makes you feel better. Glad I use a metric **** ton of assembly lube... lol...
Southbay
Long Island, NY
HEMI 5.7
The OP has probably already taken care of this by now….but last week I dumped G05 in my coolant reservoir, about a pint in is when my brain decided to remember the OAT and HOAT thing. Still can’t figure out what the hell is in my 2013, OAT or HOAT, in any case I bought an $8 transfer pump from harbor freight and sucked the reservoir out, flushed it a few times with water and then dumped some distilled in to get me through the winter, until I can flush in the spring. The xfer pump will come in handy again when I do the full flush. Quick and easy fix.
El_Dude
El_Dude
Spring, TX
2019 Classic SLT
I was able to siphon it out. no biggie. I'll probably end up painting the cap blue.
ROYSZZ4
