idle clip.
pavester
texas
Quick clip, about 2 weeks and 200 miles after the cam. Exhaust is longtubes,no cats,hpipe and dumped under backseat
[yt]Q0WA7xKAgGA[/yt]
pavester
pavester
texas
Posting from my phone....thanks
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Sounds good, does you idle stay up or was it just cold out? Shoot me a pm and I can add you to the cam listing in the 3rd gen performance section.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Kyle, now that's what I'm talking about.... What cam is it? And how did you adjust the idle for 800? Well done..
pavester
pavester
texas
Its a 260 and a superchips 3815 on the performance 91 tune. That's it.
pavester
pavester
texas
it was cold out. it sits aroun 700 now. its gotten significantly cooler here in texas... very little problems with the superchips tuning. it stalled one time as the pcm was learning the cam then a few more times after i replaced the battery as it had to learn the cam again.
Redtruck-VA
Virginia
Are you saying you used the SC3815 to adjust the idle to 700? Or that is just normal for your truck? What did the truck idle at before the cam install?
Thanks,
pavester
pavester
texas
Thanks,
it idled a little higher than 700 i would say 850 before the cam. then just loaded the performance 91 tune and the idle settled lower on its own. i havent even adjusted shift schedules with the superchips. just the one tune and it went back in the glovebox
Redtruck-VA
Virginia
That's higher than normal, but with a cam installed it is all good. Sounds good. Do you have a 0-60 mph time?
pavester
pavester
texas
no not yet. it tends to spin the tires relentlessly from a dead stop.
