Infamous P0307 Question?
Vanterpool224
Spring Hill, TN
6.4L HEMI
So I have the infamous P0307 code for misfire in cylinder-7. I have been working on diagnosing my 2009 RAM 1500 QC 5.7L HEMI and have some interesting notes. Mileage at 132,000K. Even with the code, the engine is not running harsh. A very slight shake as the engine idles, and no lose of power or any other symptoms while driving. No HEMI-tick. I will try to attach a video sound clip later. I have the usual daily driver, driving style.
So I have been reading some of the boards and have some odd questions to the RAM community…
1. Given that there are two spark plugs per cylinder, could one of the plugs be going bad and register the misfire, given the symptoms?
2. Are the symptoms similar to a coil pack going out?
3. Could the issue be gapping the spark plug incorrectly?
I will add that I recently bought the vehicle used from a dealer, and have no clue on when parts were replaced. Looking for some input, as I 'attempt' :eek: to keep this fix at the lowest cost-level possible.
Tach_tech
5.7L HEMI
Swap the plugs with another cylinder, swap the coil with another cylinder. Run the engine and see which cylinder is misfiring, if you have a scan tool. Otherwise you’ll have to clear the codes and see what one comes back.
If the misfire is still there after swapping the plugs/coil. Swap an injector. If still on cylinder 7, make sure the injector/coil are getting power/ground. If that’s good, try a compression test/leak down. If that’s good, time to start tearing the engine down, very well could be a lifter/worn cam lobe.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
2009 came with copper spark plugs good to 36k......have you ever changed?
DJack
