Injectors, Springs?
CunningStunt
Abbeville, AL
5.7L Hemi 4X4 Crew White/Chrome
Getting a NSR NTR Cam w/ MDS, MDS Lifters for my truck and am wondering if I should also get new OEM injectors and Springs?? I am on a really tight budget and this is just a daily driver with 185k miles. Engine looked great except the cylinder that was misfiring and my heads are getting cleaned/worked now...I only had misfire on the cylinder with the failed exhaust lifter(Non MDS cylinder).
Thanks, this forum is the ****!
If your questioning the springs at all, now would be the time to change them while the engine/heads are apart. The injectors can be changed without tearing down the engine.
With 185,000 miles on the old springs,if you can swing new ones,they sure wouldn't hurt,and as Crash states,they're alot easier to change now,then later.
CunningStunt
CunningStunt
Abbeville, AL
This makes sense, thank you!!! For only 80 bucks, ill do springs.
