Installed all four Bilstein 5100's, sits higher in front??
JamesRam
AB, Canada
I just swapped out all four of my stock shocks today for Bilsteins. I set them to 2.8 in the front. It sits higher in the front, will there truck level out or will i have to take them out again and set them down to 2.1??
D33k
Las Vegas
Have you measured? And the shocks usually don't sag "break in", springs will over time but shocks typically stay at same height.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
I set mine at 2.0'
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Shocks dont settle, so if you want the front to come down some, you will need to readjust the shocks to the 2.1 setting.
JamesRam
JamesRam
AB, Canada
I might have to take them out and set them back down either way as I have the vibration issues in 4x4.
quietpeen
2021 TRX
Hellcat
now this is just what i have read on here, but i have read where people said the front settle in and dropped a little. Specifically people who added a spacer in the rear because the front was a little nose high, then were talking about taking the rear spacer out because they had rake again.
JamesRam
JamesRam
AB, Canada
Yeah I guess I'll wait and see what happens. It's going in for an alignment later today so I'm hoping that will get rid of my vibration problem. If so I will leave it the way it is for now and see what happens.
JamesRam
JamesRam
AB, Canada
If the vibration is still there after alignment I will take it back down to maybe 2.0 or 2.1 whatever the next setting is and see
h2oman
SoCal
As you can see in this pic that it looks like I'm nose high. However, the rear has about 3/4" more travel to the wheel than the front.
JamesRam
JamesRam
AB, Canada
I haven't had a chance to measure mine yet but maybe mine is the same. However I'm more concerned with the vibration now then I am about it being nose high. So I may end up taking it back apart still anyhow. But thanks.
Steve Holtz
