Installing Pedal commander
cuminslvr
Pennsylvania
3.0 Diesel
Hi all, I'm getting a 2021 1500 limited ecodiesel. I want to install a pedal commander. Had one on my 2018 and it made a big difference. I want to ask, can anyone tell me how to remove the dash panel below the steering wheel so I can access the area where the top of the accelerator pedal is and also find a place to tie wrap the pedal commander unit up in there.
I would appreciate any help, I dont want to damage the panel, and I can get up under there because my back is all fused with rods and screws.
Thanks!!:Caffeine:
NorthStar1
Rosenberg, TX
2020 Ram 1500 Big Horn/Lone Star 4x2 Crew
Hemi 5.7 eTorque
Watch this for tips...very easy to remove once you see how it is done:
Too bad you’re not in Texas as I’d be willing to install it for free given your back issues. Anything to help a fellow Ram owner...
CG2742
Mesa
Two screws on the bottom lip. Remove those. Pull panel gently. You’ll have to remove the temp sensor wire and hood release before panel will come all the way out.
Jetact
Happy Valley, OR
6.7 HO
I just put a pedal monster from banks in my 3500 and didnt have to remove any panels. Yes it s a little tight up there but only took 10 minutes to do the entire thing.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
I don't remember removing that panel when I installed mine in my 2020 Laramie 1500. But then again, I seem to be forgetting more things as I get older, so I might have just lied to you LOL
Nick@GotExhaust
Supporting Vendor
SC
You shouldn't need to remove the panel. I have installed a bunch of them by just reaching under there. In fact the 1st one I installed I did one handed while taking a video with my phone.
jdradman
St Louis
3.0 Eco diesel
Thanks!!:Caffeine:
Might consider Banks Performance "Pedal Monster". They have a comparison video that I found interesting...
https://www.bankspower.com/search.html?#!year=2020||make=RAM||model=1500||submodel=3.0L DIESEL
TonyBop
Hi all just got a new 2020 Limited and traded in a 2018 Longhorn with P31 Pedal Commander that of course I removed before I traded. My question is, is it possible to still used the P31 on the 2020. I would hate to spend another $300 for another upgraded product just because it has Bluetooth.
Tried calling and emailing Pedal Commander with no luck, terrible customer service.
Thank you
rule18
Admin
NY
2017 Rebel
Thank you
Their website says PC78 for 2019+ Rams.
TonyBop
Just heard back from Larry Sartore of Pedal Commander, it sounds like good news but I have to first go under the dash and pull apart plug to compare. If it doesn't fit I will be selling my P 31 to buy the P 78.
Tony,
If the plugs are the same then you are good to go....
Warm Regards,
Larry Sartore
rule18
Admin
NY
2017 Rebel
Tony,
Warm Regards,
Larry Sartore
Cool, if it works let us know.
