interchangeable muffler
FlaglerMegacab4x4
hey guys ive got a question im running super 10's and they sound good but I also like 40's so is there a way that I could make them interchangeable like adding flanges or just using exhaust clamps? The 10's are way shorter than 40's so I know id have weld some sort of spacing pipe onto them does anyone have any suggestions or have done it themselves? Thanks
WhiteExpress
Midland, TX
The best thing would be to get V Clamp flanges. They are designed to be 'serviceable'.
They come apart with ease and seal without gaskets.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Ok if you want to be able to adjust your exhaust pressure and sound this would be a much better solution: SuperTrapp: Performance Exhaust
Using 2 of those if you have dual exhaust would give you some massive tuning potentials. I ran one on my Nissan for years and the ability to tune it was awesome. I may even get a pair for my truck soon depends upon when the current mufflers I have decide to bust open.
FlaglerMegacab4x4
FlaglerMegacab4x4
Thanks for the suggestion but I'm not looking for anything like that just the best way to be able to run 10's one day and then unbolt them slide them out and bolt up 40's the next
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
If your gonna be changing it alot then have collector flanges welded to the pipes for the 40 series and then have a longer section of pipe put on the 10 series with a collector flange also. Thats the quickest and esiest way and all you will have to change will be the gaskets each time if they break or crack during the changes.
05daytona
You can also use these http://www.summitracing.com/search/...pe/exhaust-ball-flange-kits?retaillocation=oh, a little pricey though, so you might want to go to your exhaust guy and have him make them.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The ball falnges are a good option also. Just have to make sure they are clean because them seating sometimes is a cluster.
