Interior lights. Hmmm
ecbartosh
US
2011 Ram 1500 5.7 crew cab. Ok here goes. When the doors are open the only light that comes on is the interior back seat light. The two front ones work, they light when I push them. But not when you open the doors. The truck on my dash shows the correct door is open . so I don't think it's the door switches. Any thoughts??
Sent from my LGL722DL using Tapatalk
bhonshell37
Washington
For the front interior lights, could be as simple as pushing the lights buttons. Close the door and reopen to see if the lights illuminate
E
ecbartosh
US
No Sir.
Cosmos
South Carolina
I have the opposite problem. The visor lights and puddle lights went out too
Travelin Ram
Sounds like an issue with the body control module. At least I think that’s the correct name for it. My 2011 had it replaced under warranty.
I remember the tech told me it was $$$ so if that’s your issue hopefully there are other sources for the part. Probably find them from recyclers by now I’d guess.
tron67j
Maryland
Not sure what model you have and if they worked in the past but some trucks did not come with overhead console lights originally and were added as aftermarket work. It is possible your's were added that way and the on/off switch connector was not incorporated into the set up.
Hoff
Virginia
Have you looked through your settings? I'm a new Ram owner too, so can't speak for these specifically, but I know other vehicles I've owned have options for situations like this, where you can set only the backseat lights to turn on when you open the door. Just a thought...
