Intermittent Ignition Failure
christopherobin
Davie, FL
87 Ramcharger, one owner, 456,000 miles, 5.2 with no start on 1st crank when hot and truck sitting for 10 minutes; after waiting 20 minutes, started immediately; ran wire from +coil to +battery and started immediately; replaced ignition starter switch (badly burned G-3 terminal). NOW no start when left hot for 10 minutes but 2nd crank usually starts immediately(but took 5 separate cranks today so problem worsening); always starts 1st crank when cold. Replaced ignition starter switch, ballast resistor, coil, Engine Control Module to no effect. Ignition switch and starter relay are original. Ideas?
C
christopherobin
Davie, FL
BTW, to add to the info above, pick-up coil replaced a few years ago but distributor is factory original (altho w/new cap and rotor).
C
christopherobin
Davie, FL
To further add to the above, there are no running, acceleration or misfire issues at all with the 318 engine, a reman installed 18 months ago.
