Is it toast?
DeckArtist
Elmo, Tx
JoeCo
NY
Oh man, sorry you are having such bad luck with rams so far (IIRC you got this one after the first one you bought had some engine issues?)...any other issues or symptoms with the screen before this happened? Had my last ram (2013) have some similar symptoms like these, in addition to others, and yeah the unit was no good at that point. I ditched the truck and moved on, but was ready to do so anyway. If I were to keep it I would have most likely replaced it with something aftermarket, as these stock unit's don't seem to last especially long in my experience.
Other option I've seen as oppose to going with a stock replacement, is to take it out and send it to some company that can fix it. I just saw a thread about it here recently, I'll see if I can find it.
Edit: Saw in another post the company is called Navrepair...I know at least a few people on here have used them.
stimpy433
IOWA
Might be the camera and not the radio itself.... start by checking the connection that goes between the tailgate and the truck bed.
Does it green screen all the time or blurry backup camera/ green screen just in reverse???
phantomfixer
Lakeland
I've had issues like this before.Next morning I started the truck and it was fine
DeckArtist
DeckArtist
Elmo, Tx
Well we got a storm last night with a lot of wind so it may have just been wet started the truck about an hour ago and guess what, it works again perfectly!
Yeah I was the one that had the problem with the black truck but this one seems to be really good hope so anyway but so far no issues.
stimpy433
IOWA
If that’s the case, then check that plug between the tailgate and the truck bed.
DeckArtist
DeckArtist
Elmo, Tx
Not too bad luck actually, I really liked that black truck but luckily enough I caught the issue before it caused me any headache. I don’t know what was wrong with the camera but the tailgate was facing most of the wind and rain from last night so it may have been that. I check the connection and everything looked fine. Just glad it’s working again!
JoeCo
NY
Oh that's good, I couldn't remember the exact circumstances but I'm glad to hear it wasn't that bad. Also, I totally forgot about it just being the camera! Glad that's all it turned out to be, have had that issue from time to time as well but didn't even think of it for some reason.
DeckArtist
DeckArtist
Elmo, Tx
Yeah the black Laramie was a great truck until I heard the noise. I had it for seven days and basically on the second day I heard what sounded like a random chirp and I thought it was coming from the pulley area of the motor. As busy as I was that week I decided to look into it over the weekend. when I failed to isolate it and make sure it was the pulley I decided to drive it over to my trusted mechanic and ask him what he thought. He told me the noise was coming from inside the motor so being the seventh day I took it back. Initially they offered to fix it thinking the same thing that I had thought, that it was a pulley, but for some reason they failed to listen And took it into the shop to diagnose it. They called me a couple of days later and said yeah guess you better pick out another truck, the fix is going to be $8000.
MD
The connection will work itself loose over time. After the 2nd time this happened to me I removed the cover on the tailgate and zip tied the connection in place. Haven’t had a problem since. Now I just need my radio to turn off when it’s supposed to [emoji58]
JoeCo
NY
Wow I guess you caught that just in time, big picture looks like it worked out as good as it could if the truck was going to have a catastrophic failure like that. Good to have a trustworthy mechanic around like that!
JoeCo
NY
How long is it staying on?
DeckArtist
DeckArtist
Elmo, Tx
Yessir....I was very thankful. He saved me from a disaster.
MD
30secs. It’s not the engine off setting. That’s all set to zero. After the engine is off and the driver’s door is opened it should shut off regardless of the setting. Seems like I need an update. It’s all on another thread. Don’t want to hijack this one.
JoeCo
NY
Ahh gotcha, yeah sounds like something is wrong there, I'm pretty sure once I open my door it cuts everything off. Good luck with it, hopefully you can find some answers. At least it's shutting off after the 30 seconds, rather than never turning off like I've seen in some other threads.
