Is my spare useless?
Dmopar74
Factory spare is 275/70/18, new tires are 305/70/18. I'm thinking I can't use my spare without screwing something up?
VicViper
Memphis, TN
Overthinking it, 305 on flat? Use the spare...get the 305 replaced/plugged/repaired, then put the spare back under the truck. Of course the handling is going to be different with the smaller spare.
Sent from my iPad using Tapatalk Pro
D
Dmopar74
Just wondering incase I ever get a blowout that I can't plug
07MegaCabRam
Chandler, Arizona
6.7L CTD
You are SMART for thinking this! Most people don't even think about it when doing larger tires etc. On a solid front/rear axle.. can be pretty bad if one tire is spinning at a way faster rate than the other!! Blow them gears!!!
You should be good!
Diameter inches (mm) 33.16 (842.2) 34.81 (884.2) 1.65 (42) 5% difference.
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
Most manufacturers say if you get a flat on a rear to take a wheel off the front and put the smaller spare up there. Saves the rear diff. Of coarse that was back when the front diff would disengage, not sure if it would make a difference now.
NewBlackDak
6.7L Cummins
The hubs are disengaged on current gen HDs, unless you're running in 4WD.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Aren't the donut spare's they put with a lot of cars a smaller diameter? Don't think it is really going to matter as temporary fix.
BBRAM2500
stony plain Alberta
It will be fine the only trouble arises when your using 4wd and even that only really is if you hit hard pack binding may happen if you can throw it on the front and drop everything in 2wd you will be fine
cattaco
na
na
Also if you have a limited slip you shouldn't use different size tires.
U&A
2016 3500 SRW
6.4 HEMI
Max out the PSI in your spair. When you need it, Drop the psi in the other 3 to a safe psi but still lower. You will be supprised that you can loose a good .5" or more depending on how fast you plan on driving is whst should determine how much you can comfortably let out. Just drive it directly to the tire shop. And dont go fast.
It will be fine. Like airing down for iff road.
