Laramie Interior Handles
Ram Man
FL
2013 Sport
Well I did it! (Driver side done, passenger side is almost identical process, in the mail)
Huge thanks to Benny for supplying the parts needed and answering all of my questions throughout this project!
The part numbers for the door panel bezel with leds are listed on post #31 of this thread.
Stock sport handle bezel vs laramie bezel with led
Behind the door panel is your door module brain that controls everything (mirrors, windows, etc).
C5 connector is what you want to use
The new led comes with a plug on the end that I snipped off immediately. What you're left with is a positive and negative wire, pretty basic. I soldered an extension 20 awg wire to it then on the other end soldered a connector pin so that I could populate the C5 connector. Huge thanks to Benny for this info! I looked ALL over for days and came up with nothing. You want to populate pin 3 and 9. Make sure you test which wire goes to what pin before you make it permanent. To test it just put the pins in and twist the headlights on, if the led turns on youre good to go. If it doesnt swap them and try again.
:happy107:
matt.davidson09
2013 RAM 2500 Laramie Mega Cab
6.7L Cummins
Sharp! Would like to see some nighttime pictures too
matt.davidson09
6.7L Cummins
[emoji54] fancy!
Naydolf
:happy107:
That looks really good!! Did you replace the whole door panel and everything? And who is this benni guy that helped you?
Ram Man
FL
2013 Sport
Benny is with allmoparparts.com, they are a vendor on here.
And didnt replace anything but the door handle bezel. Thats what the first pic is
Buckeye2019
2018 Cummins
Do you have any more pics of the wireing also did you do the rests. Any pics
Aikido187
So do you think that this upgrade could be done on an Express?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Yes, but you'll need new door panels first. The handle bezel is a different shape.
You could DIY it and wire an LED of your choosing the sane way he did though.
R
rango10
Ok, those appear to be the "premium" part number.
You will also need the screw covers if you don't already have them
1WD62LA8AA COVER-RELEASE HANDLE BEZEL
1WD63LA8AA COVER-RELEASE HANDLE BEZEL
In the above numbers, change LA8 to DX9 for black instead of diesel grey screw covers.
The non-lighted (cheaper) part number appears to be
1WD58LA8AC BEZEL-RELEASE HANDLE
1WD59LA8AC BEZEL-RELEASE HANDLE
Can you post a pic of the part numbers?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
What exactly are you trying to see?
Here is an installed pic...
oe542bob
Hemi eTorque 5.7
Oh crap, now I see something so cool I may need to do this too! Great thread!
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
What do you mean by "premium"? I have a 2014 Sport with the black interior and wanted to this mod with the door handle led lights for front & back doors. Also, did the ones you order ($12 each) come with the led?
Sir John
Buffalo, NY
:happy107:
Awesome. Can you help me with which pin is 3 and which pin is 9 on the connector? Which are the positive and negative? Are they the same on the back doors? I feel like you had pics on here but they are gone??? :shrug:
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Mine are without LED. You want the parts from Ram Man's post.
R
rango10
Anyone know if these can be installed in the rear doors on my 15 Sport
DeereGuy
Pittsburgh, PA
Just got a set of Laramie panels for my 2016 crew cab. I ordered the handle trim with leds per this post. Also ordered connectors and pins to build a custom harness instead of splicing wires. The only question i have is will the window and door lock module out of a tradesman work in the Laramie panels? My current ones look like they have a wide black trim on them and the Laramie panels look like the are finished around the cutout with chrome and the module sits down in them.
kevinsayers
What would you estimate the total cost of the mod? Thx.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I think so. When I switched panels only the handle trim had to be replaced. If you take a picture I could tell you for sure.
