led headlight bulbs
JOe G
Broken Arrow OK
hemi
Just replaced my stock/lousy stock 2012 SLT bulbs and now have no low beam. Any thoughts?
TatertotScott
The man, the myth, the legend, the one and only!
La Center/Amboy, WA
Plugged backward?
LED require pos/neg to be aligned correctly.
Common sense isn't...nor is common decency.
BOWERSFJ
Uniontown OH
Which LED’s did you install ?
BOWERSFJ
Uniontown OH
You have quads or duals ? Cuz the low beam bulb for quads is H11 ...
bryce88
Utah
It may be a bulb orientation problem. It looks like those bulbs can be indexed with a set screw. You could also testing the bulbs outside of the housing to see how they're working
JOe G
JOe G
Broken Arrow OK
hemi
I have tested them out of the housing. The LED bulbs have three sides, two are low, one is high. Only the high side is lit. I reinstalled the original bulbs and still no low beams. At least the high beams are so lousy I don't think it will bother anyone.
BOWERSFJ
Uniontown OH
Return em and check into Vanquish Auto ...
JOe G
JOe G
Broken Arrow OK
hemi
It is not the bulbs, I put the original back in and still have no low beam.
