Leveled with heavy duty rear springs
FLAKES15
Hi all, im new here and I am researching about bilsteins at 2.8 installed with heavier rear springs that lift you bout a inch or so. I will be towing a camper so don't want it to sag to much. Thanks
armymgdude
I have that exact lift. Bilsteins at 2.8, and tufftruck springs. I have a topper and custom cabinets inside full of search and rescue gear. That sits at a slight rake, with towing about 300lb tongue weight it sits level.978dfb9471c0fbe125d55ef912c91546.jpg
FLAKES15
FLAKES15
Looks awesome, what size tires and how much lift did the springs give you. Also what weight percent did you get. When I was looking them up I saw 20% stronger or 50?
armymgdude
Tires are LT 265 70R17s load range E. I have the 50% stronger springs, not the variable rate. It still rides great, but I have a constant load in the bed over 500lbs.
FLAKES15
FLAKES15
Cool, thanks for the info, so you deff saw a difference in them springs then huh. Also did you need new shocks with them and how much lift does the 50 give you empty. It says 3-4
armymgdude
I have bilsteins in the back too. They are 1 in longer than stock. It does sit at least 3 inches taller than stock with no load. I have yet to get it to sag, even with my car trailer loaded.
FLAKES15
FLAKES15
Thanks for all the info, think that's what I'm going to do, just hope the truck empty won't look funny.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
So are these rated to haul up to 50% more then stock ? If so that puts the 1500 close to 3000lbs instead of the 1600lbs it is rated for.
Thanks for posting pictures and the info.
CherryRed
South West Virginia
HD rear springs can increase payload. However you will start running into limitations with other items on the truck, such as the tires, wheels, rear axle & differential and brakes. Obviously tires and wheels are easy to upgrade. So this leaves the rear axle and brakes.
IHMO HD rear springs should be looked at as something that allows the truck to better manage a load, and not necessarily increase the truck's load rating.
IIRC, the rear axle on the 1500 is rated for a maximum of 3900 pounds. You must subtract the truck weight from that 3900. Even given this conservative rating, putting 3000 pounds into the bed of a 1500 is asking for trouble.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
That was kinda my question and point, just adding springs and doubling the payload is alittle much and wondered if they really mean 50% increase in the load.
But these springs would probably give me the added load capacity I would need if I end up with a 1500.
Taylo1
Childress, Texas
Why are they not suited for the Outdoorsman? Note: Not suited for the 2WD regular Cab/Shortbed RT & the Limited Outdoorsman
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
3000 lbs in the bed of a 1500? Us 2g boys do that all the time.
:crazy:
:naughty:
:burnout:
Fatboy1989
