Leveling kit
atrimpe1993
Hemingway 5.7
I ordered a 2" leveling spacer kit for my 2016 ram would I need to order new upper control arms or what is needed??
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
You dont have to, But you can have problems with the stock ball joints.
not sure what the odds are on having problems is I think its low though.
A
atrimpe1993
Hemingway 5.7
Alright because that's all I've been hearing bout is the ball joint issue
A
atrimpe1993
Hemingway 5.7
With spacers you have a much higher chance of the ball joints popping.
What's the chance if I don't do alot of rough terrain driving
quietpeen
2021 TRX
Hellcat
It can still happen. The mevotech's aren't too expensive but by the time you buy them too you are close to the cost of bilsteins
12sportmc
NC
Mine lasted 18k with just highway driving and then gave out. Switching to bilstiens I have the Zone UCAs now but the mevotechs are a cheap and easy upgrade as well
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Agreed. I know you said you already purchased your 2" spacers, but if you're considering replacing the UCA's, you might as well just get the Bilstein's and return your spacers.
Adam
firemedic10584
Central Fl
Adam
Assuming he's a 4wd. If you're a 2wd OP, I'd return the spacers and go with Maxtracs 2.5" lift coil with shocks. Ride quality is better and the angles on your balljoints aren't near as bad. It's more expensive, but definitely worth it.
quietpeen
2021 TRX
Hellcat
Good point.....I just assumed he was 4x4 since he was asking about the uca issues
R.L.K.
Bristol , Tn.
Adam
Well said Sir !
Sent from my SM-G900V using Tapatalk
