Looking for LEDs
Rasheed
Houston
I have a 2017 with projectors and I'm finally switching to LEDs.
I've been trying to find a a set of LEDs that match the color of my XB LED Fogs.
I've searched different forums and threads and I can't seem to find a set that actually matches.
I don't drive at night so they don't have to be the brightest set out there, but they need:
Same hue as the fogs
clean line
good quality
small enough they can fit inside the headlight without overstuffing the compartment
Any pictures and recommendations would be great!
JoeCo
NY
What color are your fogs? They usually are somewhere between 5000-6000k but can certainly differ. If you have that info, just look for LED bulbs for your low beams that have the same color temperature. Or let us know what color temp your current fogs are and I'm sure plenty of us will have recommendations. I'm a few months into having Hikari Ultra 6000k's in my low beams to match my 6000k fogs.
R
Rasheed
Houston
It’s the retro shops xb led whole fog light assembly running the Luxeon-T 5000K LED.
JoeCo
NY
So for starters you'll be looking for 5000k color temp. Since I have the 6000k I can't answer the other specifics you had asked about but surely someone else will have some input that runs the 5000k. Unless Hikari makes the ultra in a 5000k, which they might, and in that case I'd feel comfortable recommending them to meet your other requirements.
bigred90gt
I had the Morimoto XB LED fogs on my 17 with the Alpharex 2019 style headlights and the Katana LEDs were close enough in color that you could not perceive a difference when looking at them. The only issue I can see will be fitting the LEDs into the housing on the OEM projectors. It's going to be tight without modification to the dust cover.
Carbary
