hopalong1949
I have a 2020 1500 with 5.7 hemi. Looking to upgrade to pull a 1200O lb rv and would like suggestion as to whether I should go with 6.7 gas engine or go diesel and what size rear end do I need to pull the best?
Above 10,000 lb = diesel, in 3500 series. In 2500 series, the high weight of the diesel reduces payload too much.
You can only get a diesel with 3.92 gearing in the 1500 for which a 12K lbs trailer is a bit too much.diesel hands down IMO. 3.92 rear period. Just go 3500. If 5th wheel duelly
Mine did too on my older Duramax and PSD motors. But that's not a thing anymore with my 18 Cummins. There is no stink no more.wife hated the smell of diesel exhaust.
Best answer you'll get right here.When asking about towing, concern about engine and gearing ignores other critical attributes that are as important or maybe even more so.
No one can give you an answer you can be sure is anywhere near what you need because there are too many data points missing. What type of gear do you carry in your truck when traveling, how much weight is added with family, pets, and friends, do you want 4wd, how much exactly does your trailer weigh full for camping and what is the exact tongue weight? Just some of the questions anyone here needs to give you sound advice. A 12k trailer empty can easily hit 13.5k with all the stuff, supplies, and fluids carried in the trailer. Or the 12k could be the maximum loaded weight of your trailer and you are a minimalist.
Lots of people tow safely within specs, others take chances that can lead to unwanted consequences. Where do you want to be in this spectrum?
You could be well within specs, save a ton of money, and be very happy with a 2500 6.4 with 3.73 gearing if you get a Tradesman 2wd crew cab. My family has a couple of these working great. We also have 1 tons with diesel that are doing their thing. Each rig was spec'd out for the intended purpose and trailers are not just bought for the look and features but also with an eye on if it works within the parameters of the truck or not.
Once you know all the weights of your trailer, plus the weights mentioned above that go in the truck (include the actual weight of the hitch), then you can find the right truck for the job. Good luck.
