Lost AUTO Temp Controls after new battery
stretch78681
Texas Hill Country
2018 BIGHORN
5.7 squirrel cage
For the second time in a month my battery died. I decided to replace it. Using normal practices. Remove ground, then lead. Upon replacing the battery in same manner, the vehicle started and all was good until we got on the road. With the 8” A/V control in my 2018 Bighorn 4dr, I seem to have lost temperature control. I have “HOT” or “LO”, and fan controls. LO, with MAX A/C I get air conditioning. Otherwise I get heat. I did hold my finger on the circle around HI, the temperature numbers displayed, I set the control to 72, when I released my finger, the display went to LO.
I have held buttons down, counted to 10, checked fuses. Nothing changes.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
As previously stated, if the radio looses power it will take several hours/power cycles for the features to read correctly after the BCM is read.
Sherman Bird
Houston, Texas
Time to sell it for scrap. LOL!
I'd try one last thing and PULL the battery terminals. Let it sit overnight to fully drain off any residual power. Then connect the battery and see if it finds everything and initializes it. Short of that... a trip to the mechanic. Auto climate control is electronics and not as easy to trouble shoot.
You are proposing a deep reset. Both terminals MUST be removed from the battery and a 100 ohm resistor put between them as you connect them. The MAXIMUM time for this connection is about 18 minutes. Either it works or it doesn't.
Pull the negative cable / step on the brakes for a minute or 2 and turn on the headlights at the same time,then reconnect the negative cable and don't touch the truck again for at least a couple hours,do not cycle the key during that time,and see what happens
stretch78681
stretch78681
Texas Hill Country
2018 BIGHORN
5.7 squirrel cage
That was what happened when I replaced the battery.
Dusty
Rochester, New York
Situations like this are usually avoided by disconnecting the two-wire IBS connector that's part of a sensor mounted to the negative terminal of the battery. BEFORE disconnecting the positive or negative battery cables.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 124583 miles.
