Lost FOB Replacement Question
Louise
Missouri
V8
hello,
So I lost one of my Key Fobs for my 2014 Ram 1500 Laramie. It is the fob for the enter n go where I don't have an actual key to start it I just hit the break and hit the start button.
I’ve looked on the net however I’m not sure if I know the correct terminology to get a replacement. Can anyone give me details of how I can find a replacement other than going to the dealer?
I appreciate all info that leads me to a solution. Right now I can’t go anywhere!! I have a second vehicle but this is driving me crazy cause I can’t figure out how I lost it.
Thanks for your help,
Louise D
big daddys house
Hill Valley
hello,
Louise D
Welcome to The Forum Louise!
The link below will take you to the correct key fob. You have two choices of how to get this programmed. Of course take it to the dealer..... Or use Alfaobd. If you decide to go to AlfaOBD route you will need to get your 4 digit PIN from the dealer or use the app called pin puller.
https://www.amazon.com/dp/B07D7DWR7F/ref=cm_sw_r_sms_awdb_t1_br-fEbQJMF8KK
This is the RAM FORUM AlfaOBD thread:
https://www.ramforum.com/threads/alfaobd.123982/
Sent from my LG-LS995 using Tapatalk
Toolman
Middle TN
If you use AlfaOBD, who would cut the metal key?
Adam Duron
San Francisco
Ram
hello,
Louise D
Hey , Louise.
Unfortunately I had the same situation before. Here is some useful information that’s helped me save a lot of time and money. Hope it will help you as well:
I guess there is a huge difference between different keys, models, etc.
Also locksmiths and dealers charge different amounts for the very same key.
It helped me save a lot of money (more than $150).
Generally speaking, to get a replacement key, you have three options:
1.Call an automotive locksmith that offers a mobile service for cars. Here is a phone number for a company that have many different locations and locksmiths: 800-223-1453. I think they work all around the US but not sure. Give them a call and ask.
2.Tow the car to the dealer.
3.Order a key online and have the dealer or locksmith cut and program it for you (if necessary).
Here is the link to read more:
https://lost-car-keys-replacement.com/dodge/ram/
If you do call a locksmith or the dealer, don’t forget to mention some important information so they will check if they have the key blank and the necessary tools to code you the new key:
1.Year, make and model of the car
2.Your exact location including street address and zip (for the locksmith to find you easily)
3.VIN number of the car located on the dashboard – very important
4.Make sure you can show them proof of ownership – otherwise they will not make you a new replacement key.
Regarding the cost, it really depends on the type of key you had.
There are 3 main types of keys:
Non-chip keys: for older models (mostly 2000 and older)
Transponder chip keys – these types of keys must be coded on site with a special machine, otherwise the car wont start. These are more expensive to make
Key fob – push to start – these are the most expensive types of keys. Mostly made for models made after 2015.
The average cost is somewhere between $200-$460. It also depends on your location, time of day, weekend, etc etc.
Here is the link for some additional information:
https://lost-car-keys-replacement.com/blog/car-keys-replacement-cost/
good luck!
